查看: 600|回复: 4
飞利浦philips 29PT8319/93R 开机后保护红灯闪四下是什么原因?
发表于 2010-11-25 23:40:48 | 显示全部楼层 |阅读模式
飞利浦philips pt7319/93r因天气潮湿打火后,自动关机,开机后有高压声立即保护,红灯闪四次,过几秒再闪四次,这是什么原因引起保护?急!!!
一般是场保护
 楼主| 发表于 2010-11-25 23:40:49 | 显示全部楼层
是一sbb板有问题的
发表于 2010-11-25 23:40:50 | 显示全部楼层
误码4代表是5V保护,基本可以断定是SSB板有问题。! f( b& K0 t& f7 s
: ^) ?9 D) u3 ~3 n/ r' c! F自己看下手册的说法:# O( z/ A8 x0 M( `5 u, t
        / t+ I7 f, _3 x: L+ U1 V! {! j; B
2 E( Q: i. s1 P6 F        4 U* g8 G* r' L+ m( f% L$ t' B! d( g
Error 4
- T* Z& r; G2 k. r/ SWhen the +5 V protection is active, the set is switched to6 B. H  V0 x6 s, e8 O
protection and error code 4 is placed in the error buffer. The
# P8 C2 H% k9 P. HLED will blink 4 times (repeatedly). A 5 V failure can cause3 V' |' o% R0 ]3 V# v, J
a drop in the 5 V supply output, resulting in an undefined: o8 Z  l7 p& b( q2 r
behaviour of the set. Therefore, some I2C devices (Tuner: \* v1 D% g9 Z1 L' t
and MSP) connected to the 5 V supply are constantly1 A  T% u2 n6 b* L7 n
monitored. When none of these devices responds to the
) p4 S2 o( L# @1 imicro controller for a prolonged time, the micro controller
$ }/ K5 @8 U% t1 z, O- vassumes that there is a failure in the 5 V supply. By starting2 R2 Y' v* D/ I6 r4 ]& ^, m: O7 E
up the set via grounding of the FRONT_DETECT-line (on the
9 E4 [4 Y# ~+ t) ]1 Rside I/O), the +5 V protection will be overruled and it will be
% n7 Z% g% _9 b! K+ e& h/ g7 M4 U# n3 Yeasier to determine the cause. The +5V protection will be
8 ~* U8 z# |8 ]" u( z# ~0 Factivated when these I2C devices fail (no I2C
% V) B2 f4 S6 Q2 L3 Xcommunication):4 O, r) ?) E) m& T6 L5 a! l' i
– Main Tuner (pos. 1200 on the LSP),+ P# n9 K. P) ~7 i) V- |
– MSP34xx sound processor (pos. 7651 on the SSB).
发表于 2012-4-8 22:09:07 | 显示全部楼层
就是场保护
GMT+8, 2025-4-30 21:30 , Processed in 1.359015 second(s), 30 queries .
