一台长虹changhong SF2166K(F25)总线故障,现象是可搜索,台号可增加,搜索完毕后无台,没有存储,手动搜索可以收看,此时图声正常,一旦换台又没了,另外场幅偏小,进总线调整好后,马上就还原了,行幅还偏大,现在把实录的总线数据发上来,各位帮忙看看,是哪些项目出错,先谢谢各位了。(注:有些项目不能更改), Q9 c2 |+ ]8 F/ Y7 m$ T/ t
, y4 n# j- y1 P2 ~' G
V.POS/50H 12 H.PHSE/50H 14 V.SIZE/50H 90 V. POS/60H 4 H.PH/60H 17 V.SIZE/60H 63 V.SC 13 V.LINE 19, }' c. G2 n4 a: I7 W
V.SIZE CMP 3 SUB.BRIGHT 63 SUB.CONT 63 V.KILL 0 RF.AGC 20 R.BIAS 120 G.BIAS 120 B. BIAS 120 R.DRIVE 100 G.DRIVE 15 B.DRIVE 100 B-Y.DC LEV 10 R-Y.DC LEV 10 BK SIR STA 1 BK STR GAIN 1 Y-TH 1 Y.GAIN 1 R WIDTH1 R.OFFSET 1 B.WIDTH 1 B.OFFSET 1 VRESET.T 0 V.TEST 0 H.AFC.GAIN 0 SYNC.KILL 0 H.BLK.L 3 H.BLK.R 3
2 M3 k, ]9 M( r$ m0 u& ^H.FREQ 20 HLOCK.VDET. 0 VIDEO.LVL 4 FM.MUTE 0 AUD.MUTE 1 VID.MUTE 0 DEEM.TC 0 AUDIO.SW 0 FM.GAIN 09 U4 ]6 B; g3 e& f3 t9 }8 G
FM.AUD.OUT 1 S.TRAP .SW 1 C.EXT 0 C.BYPASS 0 C.KILL.ON 0 C.KILL OFF 0 COL.KIL OP 7 PAL .APC 0 CB/CR-IN09 h2 |- ^6 }4 I* l
VIDEO.SW 0 SUB COLOR 63 SUB.TINT 31 SUB 夏普SHARP 63 S.TRAP.T 4 C.TRAP.T 4 C.BPF T 0 DVD B-Y 3 DVD R-Y 3 / n( E+ v+ v& L# ~# S
BLNK.DEF 0 FBP.BLK.SW 1 FILT.SYS 7 COLOR.SYS 5 VOL.FIL 0 VIF.SYS.SW 0 SIF.SYS.SW 3 V.CD.MODE 0
+ l7 W5 z/ c3 `! A' s aCD.FIX/50H 0 CD.FIX/60H 0 V.SEPUP 0 VBLK.SW 0 V.TRANS 0 BRT.ABL.TH 7 RGB.TEP.SW 0 BRT.ABL.DF 1
; |- q) u5 Q: P* [4 IMID.STP.DF 1 SPL.TEST 0 TINT.THR 0 Y-APF 0 WPL.POINT 0 RPE/SHOOT 0 OVER/SHOOT 0 C.VCO.ADJ 4
6 X# V. | Q* s9 [, {% s$ T! xVCO.FREQ 30 LA76931 1 T.DISBLE 1 TINT.TEST 0 COLOR.TEST 0 IF.AGC 0 CROS.B/W 0 GRAY MOD 0 OSD.CONT 35 f# s7 |% d! B' r. o
OSD.H.POS 36 AUTO.FRESH 0 CORING.GAN 3 DC.REST 1 Y.GAMMA 1 HALF TONE 3 FSC V.SYNC 0 SVO.SW 0 0 {: X, ~, _! ]' S- J; P$ ~3 [$ F
R/B G.BAL 9 R/B ANG 9 OV.MOD SW 1 OV MOD LEV 5 VCO TEST 1 OPT.SIF 3 OPT.AUTO 1 OPT.SECAM 0& W8 u1 l4 G$ E( ]3 M' {. G7 |
S.STRAT.CH 0 OPT.PW-ON 1 OPT.SCR-SV 0 OPT.TVAV 1 OPT.AV1AV2 1 OPT.AV3 0 OPT.DVD 0
3 e6 v. |% o: F+ k! l1 k9 f* wOPT.S-VHS 0 OPT.AVKEEP 1 OPT.LANG 1 OPT. ADKEY 1 OPT.D/AV2 1 TUD ADR 1 6 F9 U# p& c. Y: |# X2 ~0 n+ B. I
OPT.VID SW 1 OPT.SIF SEL 0 ROM CORREC 0 |
