以下内容含脚本,或可能导致页面不正常的代码
' h* ^7 y9 \$ m9 T<div id="threadtitle"><h1><a href="http://www.163dz.com/bbs/forumdisplay.php?fid=118&filter=type&typeid=11">[电视]</a> 创维skyworth 29TA8000水平一亮线</h1><div class="ad_textlink2" id="ad_thread2_0"> </div></div><div class="t_msgfontfix"><table cellspacing="0" cellpadding="0"><tbody><tr><td class="t_msgfont" id="postmessage_1787471"> <div class="t_attach" id="attach_189789_menu" style="DISPLAY: none; Z-INDEX: 999; LEFT: 593px; CLIP: rect(auto auto="auto" auto="auto" auto); POSITION: absolute; TOP: 422px" h="42" w="142" initialized="true" ctrlkey="attach_189789">下载次数: 0<div class="t_smallfont"><span title="2010-9-11 00:31">刚才</span></div></div>一台创维skyworth 29TA8000(可能是5T20<span class="t_tag" onclick="tagshow(event)" href="tag.php?name=%BB%FA%D0%BE">机芯</span>),<span class="t_tag" onclick="tagshow(event)" href="tag.php?name=%BF%AA%BB%FA">开机</span><span class="t_tag" onclick="tagshow(event)" href="tag.php?name=%C6%C1%C4%BB">屏幕</span>中间只有一条水平暗线,且两端均少2寸左右。查场集成TA8427K外围元件无<span class="t_tag" onclick="tagshow(event)" href="tag.php?name=%B9%CA%D5%CF">故障</span>,查TB1240(22)脚<span class="t_tag" onclick="tagshow(event)" href="tag.php?name=%B5%E7%D1%B9">电压</span>8V5(正常4V),场反馈(23)脚9V(正常4V8),场<span class="t_tag" onclick="tagshow(event)" href="tag.php?name=%CA%E4%B3%F6">输出</span>(24)脚0V(正常1V),查外围元件无故障。换TA8427、TB1240故障依旧。查两集成供电也都正常,不知故障出在何处?有关<span class="t_tag" onclick="tagshow(event)" href="tag.php?name=%B5%E7%C2%B7%CD%BC">电路图</span>附后,请帮助分析。</td></tr></tbody></table></div>[upload=pdf,创维skyworth 29ta8000(tb1240).pdf]viewFile.asp?ID=143065[/upload][upload=pdf,tb1240-elecfans1.com.pdf]viewFile.asp?ID=143066[/upload]
) W: ?9 b+ I* B) J* g说明:上面显示的是代码内容。您可以先检查过代码没问题,或修改之后再运行. |
