查看: 125|回复: 4
维修R600a冰箱(柜)操作工艺
发表于 2010-6-10 04:10:13 | 显示全部楼层 |阅读模式
以下内容含脚本,或可能导致页面不正常的代码
1 R: H+ T8 V" W7 f看到好多<span class="t_tag" onclick="tagshow(event)" href="tag.php?name=%C2%DB%CC%B3">论坛</span>上关于R600a<span class="t_tag" onclick="tagshow(event)" href="tag.php?name=%B1%F9%CF%E4">冰箱</span>(柜)<span class="t_tag" onclick="tagshow(event)" href="tag.php?name=%CE%AC%D0%DE">维修</span>的问题贴,大家对R600a也褒贬不一,或惧怕或谨慎或褒扬<font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" ">
 楼主| 发表于 2010-6-10 04:10:14 | 显示全部楼层
>异丁烷与钢,紫铜,黄铜,铝,氯丁橡胶,尼龙和聚四氯乙烯相容,这些相容的材料均可用于R600a系统。硅和天然橡胶与R600a不容,故不能用于R600a系统。</font><font face="楷体_GB2312 "></font> 毛细管<font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" "></font></font><font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" ">                 </font></font><font face="楷体_GB2312 ">用于R12系统的毛细管同样适用于R600a系统,只是流量稍有区别。</font><font face="楷体_GB2312 "><font style="FONT-SIZE: 1pt">7 l; B' r; @. f4 h- d# ^* M$ f& \</font></font><font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" "></font></font><font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" ">                </font></font><font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" "></font></font>过滤器<font face="楷体_GB2312 "><font style="FONT-SIZE: 1pt">: B- G- e" A( \% q. f</font></font><font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" "></font></font><font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" ">                 </font></font><font face="楷体_GB2312 ">目前用于R12系统的干燥过滤器均可用于异丁烷系统中,生产维修中考虑到R600a的结构性质,要求使用专用干燥过滤器XH9。</font><font face="楷体_GB2312 "></font>充注量<font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" ">                </font></font><font face="楷体_GB2312 ">异丁烷的冲入量相当于R12的40%左右,因此需要精度的制冷剂灌注设备,校准设备。</font><font face="楷体_GB2312 "><font style="FONT-SIZE: 1pt">! m: f) b+ K- p0 V" L</font></font><font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" "></font></font><font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" ">                </font></font><font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" "></font></font>电磁阀<font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" "></font></font><font face="楷体_GB2312 "><font face="Times New="New" Roman="Roman" ">                 </font></font>用于R12系统的电磁阀同样适用于R600a的系统。冰箱(柜)的系统<font face="黑体 "><span class="t_tag" onclick="tagshow(event)" href="tag.php?name=%B9%CA%D5%CF">故障</span></font>除压缩机外,无非是堵和漏。<font style="FONT-SIZE: 1pt"><font face="Times New="New" Roman="Roman" "># e$ c! K( u4 H4 x9 ?</font></font>9 ?' l( r7 z2 j4 M2 }0 c
说明:上面显示的是代码内容。您可以先检查过代码没问题,或修改之后再运行.
外星文字吗?放大一点才清楚的呀!
发表于 2010-6-10 04:10:15 | 显示全部楼层
UFO 天文 看不懂!
发表于 2010-6-10 04:10:16 | 显示全部楼层
那是拉丁文,要用放大镜看的。
GMT+8, 2025-5-20 20:39 , Processed in 2.470284 second(s), 30 queries .
