查看: 255|回复: 3
飞利浦philips 音量加不大是怎回事,
发表于 2009-11-25 01:03:14 | 显示全部楼层 |阅读模式
发表于 2009-11-25 01:03:19 | 显示全部楼层
进入 Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable        {mso-style-name:普通表格;        mso-tstyle-rowband-size:0;        mso-tstyle-colband-size:0;        mso-style-noshow:yes;        mso-style-parent:"";        mso-padding-alt:0cm 5.4pt 0cm 5.4pt;        mso-para-margin:0cm;        mso-para-margin-bottom:.0001pt;        mso-pagination:widow-orphan;        font-size:10.0pt;        font-family:"Times New Roman";        mso-fareast-font-family:"Times New Roman";        mso-ansi-language:#0400;        mso-fareast-language:#0400;        mso-bidi-language:#0400;}宾馆模式了 Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable        {mso-style-name:普通表格;        mso-tstyle-rowband-size:0;        mso-tstyle-colband-size:0;        mso-style-noshow:yes;        mso-style-parent:"";        mso-padding-alt:0cm 5.4pt 0cm 5.4pt;        mso-para-margin:0cm;        mso-para-margin-bottom:.0001pt;        mso-pagination:widow-orphan;        font-size:10.0pt;        font-family:"Times New Roman";        mso-fareast-font-family:"Times New Roman";        mso-ansi-language:#0400;        mso-fareast-language:#0400;        mso-bidi-language:#0400;}1,选择38频道.2,按遥控器上的"红键"松开,再按遥控器上的"OSD"键, {菜单键}在2秒内按完.就可以了. Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable        {mso-style-name:普通表格;        mso-tstyle-rowband-size:0;        mso-tstyle-colband-size:0;        mso-style-noshow:yes;        mso-style-parent:"";        mso-padding-alt:0cm 5.4pt 0cm 5.4pt;        mso-para-margin:0cm;        mso-para-margin-bottom:.0001pt;        mso-pagination:widow-orphan;        font-size:10.0pt;        font-family:"Times New Roman";        mso-fareast-font-family:"Times New Roman";        mso-ansi-language:#0400;        mso-fareast-language:#0400;        mso-bidi-language:#0400;}1,选择38频道,在一秒内按PICT+OSD.2,成功后在屏的底部有英文的宾馆模式推出信息.
发表于 2009-11-25 01:03:20 | 显示全部楼层
此机进入了宾馆模式了.1,选择38频道.2,按遥控器上的"红键"松开,再按遥控器上的"OSD"键, {菜单键}在2秒内按完.就可以了.不同的机型,方法有区别的!25"推出宾馆模式的方法:选择38频道,在一秒内按PICT+OSD.成功后在屏的底部有英文的宾馆模式推出信息
发表于 2011-10-22 21:58:58 | 显示全部楼层
我毫不犹豫地把楼主的这个帖子收藏了
GMT+8, 2025-5-19 17:59 , Processed in 0.465125 second(s), 30 queries .
