ta_mind | 开心 2012-4-22 21:43 |
classn_01: 6 classn_02 [LV.2]偶尔看看I
Intel发现6系列芯片组的SATA控制器存在缺陷。随着时间推移,端口输入输出性能会越来越差。
% ]8 c7 [$ i7 ^Intel现已停止出货6系列芯片组,再次出货的将是被修复的产品。
% A. @5 t; { @$ n+ j K0 oIntel有可能召回这些问题产品。对于已经买了新平台的用户,其实这并不是很严重的问题,安心使用等召回通知吧。
/ J# ?7 O2 e1 L7 V& v但对Intel来说这就是不幸了,公司将因此损失3亿元。+ [( @' B$ V7 v2 E7 ~4 ]
+ l" d; c# o0 N) y
+ P( @% z* G8 g
网友似乎在某些Intel高层的微博上发现了进一步消息:7 d6 }0 r3 P$ G$ D: Z
6系列芯片组的4个SATA 2.0接口使用时间长点后错误率会增加,系统会自动降低硬盘传输速度,从UDMA Mode 6到5到4到3到2。当然机器运行会越来越慢,直到最后主板无法识别硬盘。
5 o7 N& x9 [6 ~ ]悲惨的是,这个问题无法通过软件或BIOS修复,只能更换芯片。Intel计划2月开始批量供应新的芯片,3月应该可以有的换了。当然这会让Intel付出7亿元的代价。5 o7 P8 n2 Z5 S' Z% K0 J& r! }
另外,需要说明的是这个问题只影响SATA 2.0,不影响SATA 3.0接口,也就是说把盘接到SATA3.0接口上不会碰到这个BUG。7 J* x9 B+ b" s2 E& o
2 @% a. R; v! }这里面只是写了是6系列的芯片组,不知在笔记本上的移动系列的芯片组会不会出问题,看来只能继续等消息了,不过即使出现问题,这个BUG应该对笔记本影响也不会太大,各位买了新平台的朋友,继续坐等消息吧!
2 k" W3 Z, W: Q C
* k# w# d! T- N1 b8 ?! ~% d
5 w6 O6 z7 m/ R i4 [9 C+ o: M3 Y以下是英文原文:
, b. Z& r# q i/ W' Q: b2 n6 Q1 l1 w4 v" `/ `6 A- S V
A problem requiring a "silicon fix" is bad news in the chipset business, and sadly that's what Intel is announcing. Its new Intel 6 Series chipset, Cougar Point, has been found to have a flaw, something to do with the SATA controller. Intel is indicating that the ports can "degrade over time," leading to poor i/o performance down the road. All shipments have been stopped and a fix has been implemented for new deliveries, but it sounds like recalls will be starting soon for those with this ticking time bomb silicon within. It isn't a critical problem right now, though, so if you own a Sandy Bridge Core i5 or Core i7 system keep computing with confidence while looking for a recall notice, but it is bad news for Intel's bottom line: the company is advising a $300 million hit to revenue.
% }/ u M& Z% s& {0 N# @# b- k+ B) ?3 C2 l
http://www.engadget.com/2011/01/31/intel-finds-sandy-bridge-chipset-design-flaw-shipments-stopped/
2 l& H* ^6 c7 \7 _. t, v3 X: N% j& P" Z S$ [3 B
1 Z- \( X, ^( a |
