该部分内容回复后可见2 p3 R! C' l( {0 J
9 s3 E" m. s, L; M( imats -h) f* ~. @! b" h
! ?$ M! \! v9 q# v& B 4 M* \' A' e/ T6 |7 d3 M
MATS is short for Modified Algorithmic Test Sequence4 b, q: H$ C! @+ O: j
! z6 j% i+ D8 [& ~; R" i9 V1 X% ]
Based on an algorithm described in 'March tests for word-oriented memories'" R9 C" d" L$ {9 t; o& W
( \: M) v# I% Q/ W6 Q) Z6 z# |6 {6 b
by A.J. van de Goor, Delft University, the Netherlands. S8 B4 k2 ?) e5 g
: b8 ~4 s7 f5 t# J: A
% @, I, N3 B( x: n
MATS Options:8 |3 A/ Q3 O2 D, ~
9 G# x! v7 }, G7 k7 r9 z* m8 h-e xx Forces endpoint of test to megabyte xx 强制测试兆字节(终端)xx点
5 g [% A4 }+ j# v- K ! p# ~: B( A! Q1 i( S
-c xx Only test xx percent of the framebuffer. 仅按xx百分比测试帧缓冲区
4 _' J5 i) K; |& U T; _% B: i 6 q! o% A) k& g' R, x
-b xx Forces start of test to megabyte xx 从兆字节处开始强制测试
# Y. I. _- Q4 ^/ Y# E% Q : A% G- y& g9 P0 j8 D$ V8 j1 j( T
-o Suppress file output 禁止文件输出/ r8 I7 c; ]0 a; y* X- q
. K/ k4 [+ F0 c! K- w. n
-m xx Set the maximum number of errors to log 设置最大错误数记录(日志)& G* k$ P8 y( ]: p) j; E
0 f, s- J% K& D2 k; A
-n xx Run the algorithm on the card with index xx 以索引xx在卡上运行算法,'xxxx'在boards.dat文件中1 I; J9 k; `4 }% E# ?# ^
" O7 e# d) ?! x4 z$ s7 T 'xxxx' in the boards.dat file.
4 I$ l- J( m# W6 O) K: y; a
3 S/ t+ l: N3 S/ q6 {9 _-v Disable save & restore of VGA memory space 关闭存储和复位VGA内存空间
3 z! }0 J3 t5 j
8 j3 h$ n, I/ C-ver Display version information 显示版本信息7 {0 g& _( U8 i
7 i1 ^1 C) W) r- e- [7 G( M
-x Don't use the box algorithm 不使用寄存器算法
9 ^: r& G) n# J7 s
5 t7 N8 e) o4 L& Y# r8 j0 n% g, T' ` / c# S" x A7 J' z2 t% S( Z
& _5 @8 D. |( p% S9 [! a
" x# H; t. V* _( c
点击浏览该文件:mats.rar
(104.13 KB, 下载次数: 0)
