查看: 99|回复: 0
主板专业词汇
发表于 2008-6-18 18:21:37 | 显示全部楼层 |阅读模式
ADIMM(advanced Dual In-line Memory Modules,高级双重内嵌式内存模块)
5 ^( l# L4 p; {* v( B. D0 r6 f& WAMR(Audio/Modem Riser;音效/调制解调器主机板附加直立插卡)
' D+ |3 Y: t8 G1 a1 C. Q. b4 S1 mAHA(Accelerated Hub Architecture,加速中心架构)1 d# P; ]( Q9 N  C. l/ R. W/ `8 P
ASK IR(Amplitude Shift Keyed Infra-Red,长波形可移动输入红外线)) Z5 _. V) E' W9 Q1 Q$ s% e; v, N
ATX: AT Extend(扩展型AT)3 B9 A* R3 w0 ]- Q$ r4 F
BIOS(Basic Input/Output System,基本输入/输出系统)
& J9 [9 S$ N/ i4 CCSE(Configuration Space Enable,可分配空间)
" `( a4 ]% O4 Q$ o: n5 CDB: Device Bay,设备插架
) f# o9 U9 t6 C$ CDMI(Desktop Management Interface,桌面管理接口)  ~8 Y, y* r' N
EB(Expansion Bus,扩展总线)
0 Y* l) E* |% T% p) P/ mEISA(Enhanced Industry Standard Architecture,增强形工业标准架构)! s# J" n+ ~# ^
EMI(Electromagnetic Interference,电磁干扰)$ K5 [8 i' x$ a: {3 H+ N+ k1 G! W
ESCD(Extended System Configuration Data,可扩展系统配置数据)& A7 v! }! @/ q* r
FBC(Frame Buffer Cache,帧缓冲缓存). a* y' s+ `* Y( S% ]3 K2 i$ X
FireWire(火线,即IEEE1394标准)* _" Q. H* D4 f
FSB: Front Side Bus,前置总线,即外部总线- W$ q' s, I4 r$ c7 ~9 I7 N
FWH( Firmware Hub,固件中心)6 J  y# X' @( P% I4 z
GMCH(Graphics & Memory Controller Hub,图形和内存控制中心), P( y4 E& e' I( X3 j# V+ ~& r; ~4 _3 q
GPIs(General Purpose Inputs,普通操作输入). R& s1 K4 ]  W6 k+ C- L
ICH(Input/Output Controller Hub,输入/输出控制中心)& u+ Q2 k2 w" z* J; v6 J0 @1 W# S
IR(infrared ray,红外线)% u6 r5 J; L- d7 d4 r7 b+ F" }
IrDA(infrared ray,红外线通信接口可进行局域网存取和文件共享)% P! A. s3 L- q
ISA: Industry Standard Architecture,工业标准架构4 F( j# q9 T8 j! P
ISA(instruction set architecture,工业设置架构)2 ]) b, U. ]$ K, o* J) x: P
MDC(Mobile Daughter Card,移动式子卡)
+ q. J6 N$ s- e- tMRH-R(Memory Repeater Hub,内存数据处理中心)
; C& n& I0 V) V% Z. EMRH-S(SDRAM Repeater Hub,SDRAM数据处理中心)4 ]) m( d! _; n* x* L8 h; n. p
MTH(Memory Transfer Hub,内存转换中心)3 `: |/ `2 t) D& H6 |
NGIO(Next Generation Input/Output,新一代输入/输出标准)
. _8 f+ |8 Q8 k# ?1 W' f( ^P64H(64-bit PCI Controller Hub,64位PCI控制中心)5 q4 p4 y% W3 ?, e$ j/ G( K
PCB(printed circuit board,印刷电路板)' g8 V, \* Z* _0 t' Z6 F- O' s* _
PCBA(Printed Circuit Board Assembly,印刷电路板装配)3 {3 }# P. w  h
PCI: Peripheral Component Interconnect,互连外围设备1 x( k5 N( X! X, k( E& p
PCI SIG(Peripheral Component Interconnect Special Interest Group,互连外围设备专业组)8 M* ?  |8 N' W: D( e
POST(Power On Self Test,加电自测试)) }2 q5 L6 k/ E" l, j" G* a
RNG(Random number Generator,随机数字发生器). R2 ]+ L. e; ]
RTC: Real Time Clock(实时时钟)
' E/ l: L7 ~, I% Y+ r! [# b1 ^( u! H5 G" PKBC(KeyBroad Control,键盘控制器)
7 }7 M/ V6 [" F! t4 N$ @6 f9 [$ kSAP(Sideband Address Port,边带寻址端口)
9 ]- F( A% s8 S6 \- c+ WSBA(Side Band Addressing,边带寻址); C4 I* C7 O# P
SMA: Share Memory Architecture,共享内存结构
/ B( I6 |( ~0 U! X4 {STD(Suspend To Disk,磁盘唤醒)& T" J* f7 B1 b4 L
STR(Suspend To RAM,内存唤醒) 9 V6 u3 `0 y3 W$ ]
SVR: Switching Voltage Regulator(交换式电压调节)1 ]: w3 m$ W1 |& k, ^
<!--EndFragment-->
GMT+8, 2025-5-1 21:32 , Processed in 3.272348 second(s), 29 queries .
